Transports and Interfaces: Siebel Enterprise Application Integration > EAI JMS Transport > Configuring the EAI JMS Transport >
Creating a JMS Subsystem by Using the Siebel Web Client
The following is an alternative procedure for creating a JMS Subsystem by using the Siebel Web Client and then configuring the JMS Transport.
To configure the JMS Transport by using the Siebel Web Client
  1. In the Siebel client, navigate to the Administration - Server Configuration screen, Enterprises view.
  2. In the top list applet, select the Enterprise Server that you want to configure.
  3. In the middle applet, click the Profile Configuration tab.
  4. Click New to create a new component profile and set the following parameters:
    Name
    Value
    Profile
    JMS_Q1ReceiveDispatchSend
    Alias
    Subsystem Type
    JMSSubsys
  5. In the Profile Parameters list applet (the bottom applet), specify the parameters required for the type of operations the subsystem will support (for example, Receive or ReceiveDispatchSend).
    For example, if this subsystem needed to support the ReceiveDispatchSend operation, then at least the following values must be set:
    Name
    Value
    ConnectionFactory
    examples.jms.QueueConnectionFactory
    JVM Subsystem
    JAVA
    ReceiveQueue
    examples.jms.fromSiebel
    SendQueue
    examples.jms.toSiebel
    Receive Timeout
    1000
Transports and Interfaces: Siebel Enterprise Application Integration Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
