Transports and Interfaces: Siebel Enterprise Application Integration > EAI JMS Transport >
Sending and Receiving JMS Messages
The following procedure describes how to set up the Siebel application to send a message to an external system using the EAI JMS Transport and receive a corresponding reply from the external system.
To send and receive messages with the JMS Transport
  1. Set up a JMS queue to receive messages from the Siebel application and give the queue an easy-to-identify name, such as fromSiebel.
    Refer to your JMS provider documentation on how to administer, monitor, and define new persistent queues.
  2. Set up a JMS queue to send messages to the Siebel application.
    Refer to your JMS provider documentation on how to administer, monitor and define new persistent queues.
    1. Give the queue an easy-to-identify name, such as toSiebel.
    2. Create a message in the queue.
      NOTE:  To test this scenario adequately, you must have a partner application that can place a valid message for the Siebel application into the queue.
  3. In Siebel Tools, set up a workflow for sending a message out and receiving a message in response using the EAI JMS Transport. Define the flow as shown in the following figure.
    NOTE:  For details on the Business Process Designer, see Siebel Business Process Framework: Workflow Guide.
  4. Create the following process properties:
    Name
    Data Type
    In/Out
    Default String
    Comments
    OrderXML
    Binary
    In
    Not applicable
    Not applicable
    JMSConnectionFactory
    String
    In
    examples.jms.
    ConnectionFactory
    JNDI name of the JMS connection factory
    JMSReceiveQueue
    String
    In
    examples.jms.toSiebel
    JNDI name of the queue
    JMSSendQueue
    String
    In
    examples.jms.fromSiebel
    JMSReceiveTimeout
    String
    In
    180000
    Not applicable
    Order Message
    Integration Object
    In
    Not applicable
    Not applicable
  5. Set up the first step of the workflow to use the Siebel Order ASI with the QueryById method to query the information from the Siebel database using the following input and output arguments:
    Input Argument
    Type
    Property Name
    PrimaryRowId
    Process Property
    Object Id
    Property Name
    Type
    Output Argument
    Order Message
    Output Argument
    SiebelMessage
  6. Set up the second step of the workflow to use the EAI XML Converter with the IntObjHierToXMLDoc method to convert the data extracted from the Siebel database to XML using the following input and output arguments:
    Input Argument
    Type
    Value
    Property Name
    GenerateProcessingInstructions
    Literal
    False
    Not applicable
    SiebelMessage
    Process Property
    Not applicable
    Order Message
    Property Name
    Type
    Output Argument
    OrderXML
    Output Argument
    <Value>
  7. Set up the third step of the workflow, after Start, to use the EAI JMS Transport with the SendReceive method using the following input and output arguments:
    Input Argument
    Type
    Property Name
    <Value>
    Process Property
    OrderXML
    ConnectionFactory
    Process Property
    ReceiveQueue
    Process Property
    JMSReceiveQueue
    ReceiveTimeout
    Process Property
    JMSReceiveTimeout
    SendQueue
    Process Property
    JMSSendQueue
    Property Name
    Type
    Output Argument
    OrderXML
    Output Argument
    <Value>
  8. Set up the fourth step to use the EAI XML Converter with the XMLDocToIntObjHier method to convert the XML message to an Integration Object using the following input and output arguments:
    Input Argument
    Type
    Property Name
    <Value>
    Process Property
    OrderXML
    Property Name
    Type
    Output Argument
    Order Message
    Output Argument
    SiebelMessage
  9. Set up the last step to use the Siebel Order ASI with the Synchronize message to update the Siebel database using the following input and output arguments:
    Input Argument
    Type
    Property Name
    SiebelMessage
    Process Property
    Order Message
    Property Name
    Type
    Output Argument
    Order Message
    Output Argument
    SiebelMessage
  10. Save and deploy the workflow.
    It is recommended that the Workflow Simulator be used for testing purposes.
    NOTE:  To test this scenario adequately, you must have a partner application that can accept the message and return a response. The correlation ID of the response message must be set to the message ID of the message originally sent by the Siebel application.
Transports and Interfaces: Siebel Enterprise Application Integration Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
