Transports and Interfaces: Siebel Enterprise Application Integration > EAI MSMQ Transport > Configuring EAI MSMQ Transport for Various Send and Receive Scenarios > About Defining Integration ObjectsBefore you use the EAI MSMQ transport, you must define integration objects for use with the transport. The various methods explained in the following pages assume that this integration object has already been defined. You define your Siebel messages as integration objects using Siebel Tools. These messages correspond to the information that you want to exchange between the Siebel application and an external application. An example of an integration object would be an order, an account, a quote, or a contact. After you have created an integration object, you can then send the message corresponding to this integration object through the EAI MSMQ Transport, either as part of a workflow or as a custom business service. For information about creating integration objects, see Integration Platform Technologies: Siebel Enterprise Application Integration. |
| Transports and Interfaces: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
