Table 10. EAI MSMQ Transport Parameters
EndOfData |
Set to True to indicate end of data. |
MsmqPhysicalQueueName |
Name of the MSMQ Queue. Can be used for both sending and receiving messages. |
MsmqQueueMachineName |
Computer that owns the queue specified by the physical queue name. |
MsmqRespQueueMachineName |
Computer that owns the queue specified by MsmqRespQueueName. |
MsmqRespQueueName |
Name of the response queue. |
MsmqSleepTime |
Default is 20000 milliseconds. The amount of time that the EAI MSMQ Transport business service waits to receive a message. |
TimedOut |
If no message is received in seconds specified in SleepTime, then the TimedOut argument in the Output Property set is set to True. |
IgnoreCorrelationId |
Default is False. Set to ignore Correlation Id value on the inbound messages. If this flag is True, then the message is picked up from the queue regardless of the correlation Id on the message. This parameter is ignored for the SendReceive Method because Correlation Id is required to match the response with the original message. |
LargeMessageSupport |
Default is True. Set to enable or disable large-message (messages over 4 MB) support. Set IgnoreCorrelationId to False for Large Message Support. |
