Transports and Interfaces: Siebel Enterprise Application Integration > Integrating Siebel Business Applications with Java Applications > About the Siebel Code Generator >
About Methods of Java Classes Generated for a Business Service
Table 22, Table 23, and Table 24 describe methods that are present in the generated Java code for every business service. Generic names (for example, GenericService and GenericMethod) are substituted for the actual names of the business service, methods, and arguments. Methods for Java class com.siebel.service.jdb.GenericServiceBusServAdapter
Table 22 lists methods of the Java class com.siebel.service.jdb.GenericServiceBusServAdapter generated for an example business service, GenericService, having the business service method GenericMethod.
Table 22. Java Class com.siebel.service.jdb.GenericServiceBusServAdapter Methods Generated
GenericServiceBusServAdapter() |
Constructor that uses the default properties file, siebel.properties. |
GenericServiceBusServAdapter(SiebelDataBean) |
Constructor that reuses the resources of an existing SiebelDataBean. |
GenericServiceBusServAdapter(String) |
Constructor taking the name of the properties file to use. |
GenericServiceBusServAdapter(String, String, String) |
Constructor taking the username, password, and connect string. |
GenericServiceBusServAdapter(String, String, String, String) |
Constructor taking the username, password, connect string, and language. |
GenericMethod(GenericMethodInput) |
Invokes the specified business service method. |
Methods for Java class com.siebel.service.jdb.GenericMethodInput
Table 23 lists methods of the Java class com.siebel.service.jdb.GenericMethodInput generated for an example business service method, GenericMethod.
Table 23. Java Class com.siebel.service.jdb.GenericMethodInput Methods Generated
GenericMethodInput() |
Constructor. |
GenericMethodInput(SiebelPropertySet) |
Constructor that sets its fields from the given property set. |
fromPropertySet(SiebelPropertySet) |
Copies field values from the given property set. |
toPropertySet() |
Returns a SiebelPropertySet with the properties and values corresponding to the fields of this object. |
getfGenericArgument() |
Returns the value of business service method argument. |
setfGenericArgument(String) |
Sets the value of a business service method argument. |
Methods for Java class com.siebel.service.jdb.GenericMethodOutput Methods
Table 24 lists methods of the Java class com.siebel.service.jdb.GenericMethodOutput generated for an example business service method, GenericMethod.
Table 24. Java class com.siebel.service.jdb.GenericMethodOutput Methods Generated
GenericMethodOutput() |
Constructor. |
GenericMethodOutput(SiebelPropertySet) |
toPropertySet() |
getfGenericArgument () |
setfGenericArgument () |
