Transports and Interfaces: Siebel Enterprise Application Integration > Transcode Service Business Service > Transcode Service Business Service Methods >
Convert Method
This method converts the value in the input property set to the target encoding in the output. You use this method when data enters or leaves Oracle's Siebel Business Applications and conversion is required so that the next software component in the processing chain can recognize the data. The Convert method has the method arguments shown in Table 30.
Table 30. Convert Method Arguments
<Value> |
Yes |
Data to convert. |
ConversionMode |
Yes |
The mode can be StringToEncoding, EncodingToString, or EncodingToEncoding. |
SourceEncoding |
No |
Encoding from which data is converted. Required for the EncodingToString and EncodingToEncoding modes. |
TargetEncoding |
No |
Encoding to which data is converted. Required for the StringToEncoding and EncodingToEncoding modes. |
IgnoreConversionErrors |
No |
To ignore character conversion errors (invalid-character errors or substitution errors), set IgnoreConversionErrors to TRUE. NOTE: This argument is not shown in Siebel Tools.
