Transports and Interfaces: Siebel Enterprise Application Integration > Transcode Service Business Service > Transcode Service Business Service Examples >
Using the Validate Method
The following examples demonstrate the use of the Validate method of the Transcode Service business service:
XML Hierarchy Example
In this workflow example, a file encoded in codepage 932 (Japanese) is read into an XML hierarchy, then validated for conversion into codepage 1252 (Western European).
To create the validation workflow
  1. Create a workflow as follows:
    NOTE:  For details on the Business Process Designer, see Siebel Business Process Framework: Workflow Guide.
  2. Define the following process properties:
    Name
    Data Type
    In/Out
    Error Code
    String
    In/Out
    Error Message
    String
    In/Out
    Siebel Operation Object Id
    String
    In/Out
    XMLHier
    Hierarchy
    In/Out
  3. Set up the first business service step to use the EAI XML Read from File business service with the ReadXMLHier method and the following input and output arguments:
    Input Argument
    Type
    Value
    FileName
    Literal
    c:\JPN_JIS.xml
    Property Name
    Type
    Output Argument
    XMLHier
    Output Argument
    XMLHierarchy
  4. Set up the second business service step to use the Transcode Service business service with the Validate method and the following input arguments:
    Input Argument
    Type
    Value
    Property Name
    SourceEncoding
    Literal
    CP932
    Not applicable
    TargetEncoding
    Literal
    CP1252
    Not applicable
    ValidationMode
    Literal
    Not applicable
    Not applicable
    XMLHierarchy
    Process Property
    Not applicable
    XMLHier
Siebel Message Example
In this workflow example, an account record is read from an integration object by the EAI Siebel Adapter as a Siebel Message, then validated for conversion from UTF-8 (Unicode) to codepage 1252 (Western European).
    Name
    Data Type
    In/Out
    Error Code
    String
    In/Out
    Error Message
    String
    In/Out
    Object Id
    String
    In/Out
    Process Instance Id
    String
    In/Out
    String
    In/Out
    SiebelMsg
    Hierarchy
    In/Out
  3. Set up the first business service step to use the EAI Siebel Adapter business service with the Query method and the following input and output arguments:
    Input Argument
    Type
    Value
    Property Name
    OutputIntObjectName
    Literal
    Sample Account
    Not applicable
    PrimaryRowId
    Process Property
    Row ID of the account record
    Object Id
    Property Name
    Type
    Output Argument
    SiebelMsg
    Output Argument
    SiebelMessage
    Input Argument
    Type
    Value
    Property Name
    SourceEncoding
    Literal
    UTF-8
    Not applicable
    TargetEncoding
    Literal
    CP1252
    Not applicable
    ValidationMode
    Literal
    Not applicable
    Not applicable
    SiebelMessage
    Process Property
    Not applicable
    SiebelMsg
Transports and Interfaces: Siebel Enterprise Application Integration Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
