Business Processes and Rules: Siebel Enterprise Application Integration > Data Mapping Using the Siebel Data Mapper > Creating Data Maps > Creating Integration Component MapsOnce you have defined a data map (see Creating New Data Maps), you need to set up the mapping between the components and the fields within the objects you have mapped. You do this using the Data Map Editor form. The Integration Object Editor list displays existing object maps and provides views in which you can define maps for components and for fields. You use the Integration Component Map view to create integration component maps. To define integration component maps
Business Processes and Rules: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
