Business Processes and Rules: Siebel Enterprise Application Integration > Data Mapping Using Scripts > MIME Message Objects and MethodsSiebel EAI represents MIME documents using a property set format. This is the format used by the EAI MIME Doc Converter Business Service. The objects and methods described here provide access to this property set format, and are intended for use in conjunction with transforming pieces of the MIME message to and from Siebel Integration Messages. NOTE: The EAI MIME Hierarchy Converter Business Service is the preferred method of converting between the property set representation Siebel Messages. |
Business Processes and Rules: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
