Business Processes and Rules: Siebel Enterprise Application Integration > Data Mapping Using Scripts > XML Property Set FunctionsSiebel EAI represents XML documents using the property set format. While Siebel EAI does not always require using the property set format, this representation is used by EAI Business Services such as the EAI XML Converter. The functions described in this section provide a simple interface for manipulating XML documents using the property set format. |
| Business Processes and Rules: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
