Business Processes and Rules: Siebel Enterprise Application Integration > Data Mapping Using Scripts >
Sample Siebel eScript
This section provides a sample Siebel eScript map for transforming data from a Siebel Account to SAP to retrieve an order list. The map is used to convert between Oracle's Siebel Account object and the equivalent SAP R/3 objects. function GetSAPOrderStatus_SiebelToBAPI (inputMsg, outputMsg) { /* Input Objects' Integration Components: * Order Object (Order - Get SAP Order Status (Siebel)) * Order * * Output Object's Integration Components: * BAPI Import (Order - Get SAP Order Status (BAPI Input)) * Import Parameters */
/* * Set up EAI Lookup objects */
/* * Set up EAI Input Message objects */ var iOrderObj; // Siebel Order instance var iOrderComp; // Order
/* * Set up EAI Output Message objects */ var oGSObj; // BAPI instance var oGSImportComp; // Import Parameters /* * Find and create top-level integration object */
iOrderObj = inputMsg.GetIntObj ("Order - Get SAP Order Status (Siebel)");
oGSObj = outputMsg.CreateIntObj ("Order - Get SAP Order Status (BAPI Input)");
/* * Read int object instances from EAI message */
while (iOrderObj.NextInstance ()) {
/* * Create "Get Status" object */ oGSObj.NewInstance ();
/* * Read "Order" component */
iOrderComp = iOrderObj.GetPrimaryIntComp ("Order");
oGSImportComp = oGSObj.CreatePrimaryIntComp ("Import Parameters");
if (iOrderComp.NextRecord ()) { /* * Write "Import Parameters" component */
oGSImportComp.NewRecord (); oGSImportComp.SetCopySource (iOrderComp); oGSImportComp.CopyFieldValue ("SALESDOCUMENT", "Integration Id"); } } }
