Business Processes and Rules: Siebel Enterprise Application Integration > Defining Workflows for Siebel EAI > Sample Integration Workflows >
Import Account (File)
This is a sample workflow process that reads an XML file (c:\account.xml) and imports the account information into the Siebel environment using the EAI XML Read from File business service. The EAI XML Read from File business service converts the data and the EAI Siebel Adapter updates the Siebel database. To review the Import Account (File) sample workflow process
- Navigate to Administration - Business Process, then Workflow Processes.
- Query for Import Account (File).
- With the Import Account (File) workflow process selected, click the Process Properties tab in the bottom applet to review the process properties for this workflow process.
Workflow process properties are global to the entire workflow. For example, as shown in the following table, the Import Account (File) workflow has several properties. The Account Message is defined to identify the output of the Read File step (a parsed version of the XML Account Message) as a hierarchical structure. The Error Message, Error Code, Object Id, and Siebel Operation Object Id properties are included in the workflow by default.
Account Message |
Hierarchy |
In/Out |
Error Code |
String |
In/Out |
Error Message |
String |
In/Out |
Object Id |
String |
In/Out |
Siebel Operation Object Id |
String |
In/Out |
- Click the Process Designer tab in the bottom applet to review the process design for this workflow process.
- Double-click the Read File step to review its method and arguments.
This step uses the Read Siebel Message method of the EAI XML Read from File business service to convert XML from a file into an integration object hierarchy, with the following input argument.
File Names |
Literal |
c:\account.xml |
Note how the path and file name are specified as a string in the Value field of the Input Arguments applet.
Also note the following output property for this step.
Account Message |
Output Argument |
Siebel Message |
- Double-click the Update Account step to review its method and arguments.
This step uses the EAI Siebel Adapter business service with the Insert or Update method to read the Siebel Message and update or insert the Account object in the Siebel Database. The EAI Siebel Adapter uses the information in the XML file and the following input argument to accomplish this task.
Siebel Message |
Process Property |
Account Message |
Hierarchy |
Because the Insert or Update method is specified on the EAI Siebel Adapter business service, this step checks the Siebel Database to see if the Account object defined in the XML file already exists in the database. If the account exists, then it updates the account in the database with the account instance from the XML file; otherwise, it inserts the account into the database.
