Business Processes and Rules: Siebel Enterprise Application Integration > Defining Workflows for Siebel EAI > Sample Integration Workflows >
Export Employee (MQSeries)
This is a sample workflow process that sends an XML string for an employee to an IBM MQSeries queue. To review the Export Employee (MQSeries) sample workflow process
- Navigate to Administration - Business Process, then Workflow Processes.
- Query for Export Employee (MQSeries).
- With the Export Employee (MQSeries) workflow process selected, click the Process Properties tab to review the process properties defined for this workflow process.
Workflow process properties are global to the entire workflow. For example, as shown in the following table, the Export Employee (MQSeries) workflow has multiple properties. The Employee Message contains the object as an integration object hierarchy, before conversion. The Employee XML property specifies the Siebel object that has been converted to XML. The Error Code, Error Message, Object Id, and Siebel Operation Object Id properties are included in each workflow by default.
Employee Message |
Hierarchy |
In/Out |
Employee XML |
Binary |
In/Out |
Error Code |
String |
In/Out |
Error Message |
String |
In/Out |
Object Id |
String |
In/Out |
1-548 |
Siebel Operation Object Id |
String |
In/Out |
Note that the Object Id process property is set to 1-548 in the Default String column. This string identifies an actual employee record in the Siebel Database by its Row Id. You can set this workflow to use the active employee record instead of specifying a hard-coded employee number. You can accomplish this by creating a button that invokes this workflow from the Administration - User, then the Employees view, or you can pass the value of the Object Id into the workflow process as an input argument.
- Click the Process Designer tab in the bottom applet to review the process design for this workflow process.
- Double-click the Get Employee step to review its method and arguments.
This step uses the Query method of the EAI Siebel Adapter business service, with the following input arguments to get an instance of an Employee record from the Siebel Database. The Sample Employee integration object describes the structure of the Employee business object and was created using the Integration Object Builder wizard. The other part of the query criteria is the Object Id, which is a process property containing value 1-548.
Output Integration Object Name |
Literal |
Sample Employee |
Object Id |
Process Property |
Object Id |
String |
The output from this step is passed in the Employee Message output argument as described in the following table.
Employee Message |
Output Argument |
Siebel Message |
- Double-click the Convert to XML step to review its method and arguments.
This step uses the Property Set to XML method of the EAI XML Converter business service to convert the outbound Siebel Message to XML. The converter stores the outbound Siebel Message in the Employee XML output argument with the following input argument.
Siebel Message |
Process Property |
Employee Message |
Hierarchy |
The output from this step is passed in to the Employee XML output argument as shown in the following table.
Employee XML |
Output Argument |
XML Document |
- Double-click the Send step to review its method and arguments.
This step invokes the EAI MQSeries Server Transport business service with the Send method to put the XML message onto the MQSeries queue, Employee. The message is represented by the Message Text argument, as shown in the following table.
Message Text |
Process Property |
Employee XML |
String |
Physical Queue Name |
Literal |
Employee |
Queue Manager Name |
Literal |
Siebel |
The Queue Manager that handles the request is called Siebel. The XML message is put onto the Employee queue, where it remains until another application retrieves it from the queue.
