Business Processes and Rules: Siebel Enterprise Application Integration > Defining Workflows for Siebel EAI > Testing the Workflow Integration Process >
Importing the XML File Into Siebel Tools
You import the workflow process XML file into the Workflow Processes list in Siebel Tools. To import the XML file into Siebel Tools
- In the Object Explorer in Siebel Tools, select Workflow Process.
- Right-click inside the Workflow Processes list in the Object List Editor, then choose Import Workflow Process.
- Browse for the workflow process XML file, then click Open.
The workflow process is imported into Siebel Tools.
