XML Reference: Siebel Enterprise Application Integration > Siebel XML Converters >
EAI XML Read from File Business Service
Use the EAI XML Read from File business service when you want to create a property set hierarchy in the Siebel environment from an XML document stored as a file. This business service supports both standard and EAI XML conversion. Table 41 describes the three EAI XML Read from File business service's methods. The arguments for each method appear in the tables that follow.
Table 41. EAI XML Read from File Business Service Methods
Read Siebel Message |
ReadEAIMsg |
Uses the EAI XML Converter |
Read Property Set |
ReadPropSet |
Uses the XML Converter |
Read XML Hierarchy |
ReadXMLHier |
Uses the XML Hierarchy Converter |
Read Siebel Message Method Arguments
Table 42 describes the input arguments for the Read Siebel Message method of the EAI XML Read from File business service.
Table 42. Read Siebel Message Method Input Arguments
File Name |
FileName |
String |
The name of the file to be read. This is a required field. |
Integration Object Name |
IntObjectName |
String |
Name of the Integration Object to use in cases where the Siebel Message header is not present. |
Integration Object Lookup Rule Set |
IntObjectLookupRuleSet |
String |
Rule Set for the EAI Dispatcher Service for finding the Integration Object Name in cases where the Siebel Message header is not present. |
External Entity Directory |
ExternalEntityDirectory |
String |
Directory to use for finding external entities referenced in the XML document, such as DTDs. |
Truncate Field Values |
TruncateFieldValues |
String |
Default is True. If True, then truncate any fields longer than their maximum size. If False, report fields that are too long as errors. |
Ignore Character Set Conversion Errors |
IgnoreCharSetConvErrors |
String |
Default is False. If the Siebel application cannot represent a given character set, such as the local code page character set, then conversion errors are logged, including a warning log entry. When set to True, only a warning message is logged. |
Process Elements Only |
ProcessElementsOnly |
String |
Default is False. If set to True, then processing of attributes is skipped. |
Table 43 describes the output arguments for the Read Siebel Message method of the EAI XML Read from File business service.
Table 43. Read Siebel Message Method Output Arguments
Siebel Message |
SiebelMessage |
Hierarchy |
The Integration Object Hierarchy converted from XML. |
XML Character Encoding |
XMLCharEncoding |
String |
Outputs XML character encoding to use. If encoding is blank or not supported, then an error is produced. |
Read Property Set Method Arguments
Table 44 describes the input argument for the Read Property Set method of the EAI XML Read from File business service.
Table 44. Read Property Set Method Input Argument
File Name |
FileName |
String |
Table 45 describes the output argument for the Read Property Set method of the EAI XML Read from File business service.
Table 45. Read Property Set Method Output Argument
Child type of the hierarchical process property containing the entire property set, service method arguments, and child property set. |
Hierarchical |
The entire output property set. You must manually create and name this output argument if it is required by your business needs. |
Read XML Hierarchy Method Arguments
Table 46 describes the input arguments for the Read XML Hierarchy method of the EAI XML Read from File business service.
Table 46. Read XML Hierarchy Method Input Arguments
File Name |
FileName |
String |
The name of the XML file to read. This is a Required field. |
Escape Names |
EscapeNames |
String |
Invalid characters in XML tags will be escaped, using Siebel's internal escape format.
- If True, then process Escape characters (this is the default).
- If False, then do not process Escape characters.
String |
Directory for external entities such as DTD files. |
String |
Default is False. If the Siebel application cannot represent a given character set—such as the local code page character set—then conversion errors are logged, including a warning log entry. When set to True, only a warning message is logged. |
Table 47 describes the output arguments for the Read XML Hierarchy method of the EAI XML Read from File business service.
Table 47. Read XML Hierarchy Method Output Arguments
XMLCharEncoding |
String |
Character encoding of the XML document, detected by the converter independent of the parser. |
XML Hierarchy |
XMLHierarchy |
Hierarchy |
The XML Hierarchy property set. |
