XML Reference: Siebel Enterprise Application Integration > Sample XML for Siebel EAI Effective Dating Operations > Sample XML for Field-Related Siebel EAI Effective Dating OperationsThis topic provides sample input and output XML for field-related Siebel Enterprise Applications Integration (Siebel EAI) effective dating operations. It includes the following information:
NOTE: Bold text in the following code samples indicates syntax specific to Siebel EAI effective dating functionality. Insert Field-Related OperationsThe following code shows sample input and output XML for field-related INSERT operations. Input<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:asi="http://example.com/asi/" xmlns:hous="http://www.example.com/xml/Household%20Interface"> <soapenv:Header/> <asi:SiebelHouseholdInsert_Input> <hous:ListOfHouseholdInterface> <hous:Category>Gold</hous:Category> <hous:CurrencyCode>USD</hous:CurrencyCode> <hous:EDListOfHouseholdName> <hous:HouseholdId>ASDQ-1264</hous:HouseholdId> <hous:Income>47751</hous:Income> <hous:PhoneNumber>6504234234</hous:PhoneNumber> <hous:Segment>White Collar</hous:Segment> <hous:Status>Active</hous:Status> </hous:ListOfHouseholdInterface> <asi:StatusObject>?</asi:StatusObject> </asi:SiebelHouseholdInsert_Input> </soapenv:Body> Output<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <ns:SiebelHouseholdInsert_Output xmlns:ns="http://example.com/asi/"> <ListOfHouseholdInterface xmlns="http://www.example.com/xml/Household%20Interface"> </ns:SiebelHouseholdInsert_Output> </SOAP-ENV:Body> QueryById Field-Related OperationsThe following code shows sample input and output XML for field-related QueryById operations. Input<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:asi="http://example.com/asi/"> <soapenv:Header/> <asi:SiebelHouseholdQueryById_Input> </soapenv:Body> Output<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <ns:SiebelHouseholdQueryById_Output xmlns:ns="http://example.com/asi/"> <ListOfHouseholdInterface xmlns="http://www.example.com/xml/Household%20Interface"> <Category>Gold</Category> <ListOfRelatedContact> <EDListOfFirstName> <EDListOfLastName> <ListOfRelatedOrganization> <ListOfRelatedSalesRep> <EDListOfHouseholdName> <EDListOfHouseholdSize> </ns:SiebelHouseholdQueryById_Output> </SOAP-ENV:Body> QueryBy Example Field-Related OperationsThe following code show sample input and output XML for field-related QueryByExample operations. Input<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:asi="http://example.com/asi/" xmlns:hous="http://www.example.com/xml/Household%20Interface"> <soapenv:Header/> <asi:SiebelHouseholdQueryByExample_Input> <hous:ListOfHouseholdInterface> </asi:SiebelHouseholdQueryByExample_Input> </soapenv:Body> Output<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <ns:SiebelHouseholdQueryByExample_Output xmlns:ns="http://example.com/asi/"> <ListOfHouseholdInterface xmlns="http://www.example.com/xml/Household%20Interface"> <Category>Gold</Category> <ListOfRelatedOrganization> <ListOfRelatedSalesRep> <EDListOfHouseholdName> <EDListOfHouseholdSize> </ns:SiebelHouseholdQueryByExample_Output> </SOAP-ENV:Body> Delete Field-Related OperationsThe following code shows sample input and output XML for field-related DELETE operations. Input<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:asi="http://example.com/asi/" xmlns:hous="http://www.example.com/xml/Household%20Interface"> <soapenv:Header/> <asi:SiebelHouseholdDelete_Input> <hous:ListOfHouseholdInterface> </asi:SiebelHouseholdDelete_Input> </soapenv:Body> Output<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <ns:SiebelHouseholdDelete_Output xmlns:ns="http://example.com/asi/"> <ListOfHouseholdInterface xmlns="http://www.example.com/xml/Household%20Interface"> </ns:SiebelHouseholdDelete_Output> </SOAP-ENV:Body> Synchronize Field-Related OperationsThe following code shows sample input and output XML for field-related SYNCH operations. Input<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:asi="http://example.com/asi/" xmlns:acc="http://www.example.com/xml/Account%20Interface"> <soapenv:Header/> <asi:SiebelAccountSynchronize_Input> <acc:Account> <acc:Account> </asi:SiebelAccountSynchronize_Input> </soapenv:Body> Output<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <ns:SiebelAccountSynchronize_Output xmlns:ns="http://example.com/asi/"> <ListOfAccountInterface xmlns="http://www.example.com/xml/Account%20Interface"> <Account operation="update"> <Account operation="insert"> </ns:SiebelAccountSynchronize_Output> </SOAP-ENV:Body> Upsert Field-Related OperationsThe following code shows sample input and output XML for field-related UPSERT operations. Input<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:asi="http://example.com/asi/" xmlns:acc="http://www.example.com/xml/Account%20Interface"> <soapenv:Header/> <asi:SiebelAccountInsertOrUpdate_Input> <acc:AccountId>88-30A85</acc:AccountId> <acc:Account> <asi:StatusObject>?</asi:StatusObject> </asi:SiebelAccountInsertOrUpdate_Input> </soapenv:Body> Output<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <ns:SiebelAccountInsertOrUpdate_Output xmlns:ns="http://example.com/asi/"> <ListOfAccountInterface xmlns="http://www.example.com/xml/Account%20Interface"> <Account operation="update"> <Account operation="insert"> </ns:SiebelAccountInsertOrUpdate_Output> </SOAP-ENV:Body> Related Topics |
| XML Reference: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
