XML Reference: Siebel Enterprise Application Integration > XML Representation of Siebel Integration Object Instances > Elements Within a Siebel Integration Object DocumentAn integration object can be textually represented as an XML document. In order to exchange data using the Siebel integration object document, you must have an understanding of its XML structure, including elements and attributes. The document can include up to five different types of elements: |
| XML Reference: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
