XML Reference: Siebel Enterprise Application Integration > XML Representation of Siebel Integration Object Instances > Elements Within a Siebel Integration Object Document > Object List ElementThe object list element is a container for the integration object instances. The XML Tag attribute value that you specify in the integration object definition becomes the name of this element. By default, an integration object wizard generates an XML Tag value of ListOfName, where Name is the name of the integration object, with any illegal XML characters removed—for example, spaces. NOTE: The Object List element is optional. The XML element is not generated if the Object List element is blank (omitted) in the integration object definition. AttributesChild ElementsThe object list element can include one or more instances of the integration object's root component element. A root component element corresponds to one integration object instance. |
| XML Reference: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
