XML Reference: Siebel Enterprise Application Integration > Using XML Files > Removing Empty XML TagsYou can to remove empty XML tags from messages for optimization. For example, an XML representation of an integration object might have unused integration components. You can use the siebel_ws_param:RemoveEmptyTags parameter to remove empty tags when making Web service calls. There are two ways to use the parameter:
Adding the RemoveEmptyTags Parameter to a Property Set in an Input XML FileYou add the siebel_ws_param:RemoveEmptyTags parameter to an input XML file manually as a property in the top-level property set. To add the RemoveEmptyTags parameter to a property set manually
Adding the RemoveEmptyTags Parameter as a Process Property in a WorkflowYou can add the siebel_ws_param:RemoveEmptyTags parameter to a workflow to automate the removal of empty tags. You add the parameter as a process property of the workflow, then as an input argument to the step that reads the XML file. For information on adding workflow process properties and input arguments, see Siebel Business Process Framework: Workflow Guide. |
| XML Reference: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
