Siebel Enterprise Integration Manager Administration Guide > Exporting Data > Checking Export Results > Viewing a List of Exported RowsYou can verify export results by checking a list of exported rows, as described in the following procedure. To view a list of exported rows
If error flags, SQL trace flags, or trace flags were activated for the EIM process, you can also use the trace file to view the results of the EIM process. For more information on viewing the trace file, see Viewing the EIM Log File. |
| Siebel Enterprise Integration Manager Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
