Siebel Enterprise Integration Manager Administration Guide > Running EIM > Viewing the EIM Log FileIn the Task Info Log view, you can view information about the results of an EIM process by drilling down in an EIM server task that has completed. This information is also provided in the EIM log file within the
If error flags, SQL trace flags, or trace flags were activated for the EIM process, the EIM log file will also contain the results of each flag. For more information on trace flags and error flags, see Using Trace Flags, SQL Trace Flags, and Error Flags. Further information on the EIM log file is provided as follows:
To view EIM log file information in the Task Info Log
NOTE: You can also view this information by opening the EIM log file in the |
| Siebel Enterprise Integration Manager Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
