Execute a start task command or a run task command on the Enterprise Integration Mgr component. Be sure to specify the configuration file with the config parameter.
NOTE: You cannot use the Uniform Naming Convention (UNC) in the Server Manager command-line interface when specifying the configuration file.
If you do not specify a configuration file, the default.ifb configuration file will be used. If you put the .IFB file you want to use in a directory other than the default directory (<SiebSrvr\Admin> folder), you will need to specify the path to the .IFB file when you start the EIM component.
The following example shows how to use the run task command to start an import process:
run task for component eim with config=import.ifb
For more information on the start task command and the run task command, see Siebel System Administration Guide.
CAUTION: EIM is a multistep process. When the EIM process is running, do not interrupt the task. Otherwise, some steps may not roll back correctly.
The following example shows how to use the run task command to start an import process that uses a different LOV language than the default setting of the EIM LOV language parameter:
run task for component eim with config=import.ifb, LovLang=ESN
