 Siebel Enterprise Integration Manager Administration Guide > Importing Data >
Preparing the EIM Tables for Import Processing
This section explains how to prepare the EIM tables for a subsequent import into a Siebel database. To import data, EIM reads data in the EIM tables and writes data in the appropriate Siebel base tables by making multiple passes through the EIM tables to:
- Set initial values for some columns in the EIM tables
 - Apply filter logic to select rows for importing
 - Generate foreign key references and internal values
 - Add or update relevant Siebel database rows
 - Update each EIM table row to indicate its import status
For general information on EIM tables, see Siebel EIM Tables.
