Siebel Enterprise Integration Manager Administration Guide > Importing Data > Preparing the EIM Tables for Import Processing > Required Initial Values for File Attachment ColumnsEach file attachment row must contain the filename reference to the files you want to import and the appropriate values in the following columns: FILE_NAME. Set this column to the root filename of the file attachment. FILE_EXT. Set this column to the extension type of the file attachment (such as DOC, XLS, or TXT). FILE_SRC_TYPE. This column must be set to FILE. For more information on file attachment columns, see File Attachment Columns. |
| Siebel Enterprise Integration Manager Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
