Siebel Enterprise Integration Manager Administration Guide > Importing Data > Special Considerations for Imports > Importing SolutionsThe Solution business component has the following Search Specification property: [Solution Item='Y']. For imported records of this type to be visible following an import process, you must import data from the EIM_SOLUTION interface table to the S_RESITEM base table with the value in the SOLUTION_ITEM_FLG column set to 'Y.' When importing into the S_RESITEM base table, you need to include the following columns in the ONLY BASE COLUMNS parameter in the EIM configuration file: If these columns are not included in the ONLY BASE COLUMNS parameter, a low-level error will be generated. Another requirement is that the Internal Publish flag (INTR_PUBLISH_FLG) must be set in the parent record for imports to be visible in the Solution/Resolution Documents view. |
| Siebel Enterprise Integration Manager Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
