 Siebel Enterprise Integration Manager Administration Guide > Merging Data >
Editing the Configuration File for Merge Processing
This section describes the header and process sections that you need in the EIM configuration file to properly configure EIM for a merge process. For general information on the EIM configuration file, see EIM Configuration File. Before merge processing begins, you must change the configuration file to support this function. Such changes include:
- Editing the header and process sections and parameters
 - Adjusting settings in the configuration file in the following ways:
