Siebel Enterprise Integration Manager Administration Guide > Merging Data > Editing the Configuration File for Merge Processing > Updating Affected RowsDuring a merge operation, a specific base table may have some rows deleted and others updated. You can use the update rows parameter to prevent updates to one base table while allowing updates to another. By default, update rows = true. |
| Siebel Enterprise Integration Manager Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
