Siebel Enterprise Integration Manager Administration Guide > EIM: Examples of Common Usage > EIM Import Process Examples > Example of Importing and Exporting Hierarchical LOVsYou can migrate a hierarchical list of values from one Siebel 7.8 environment to another Siebel 7.8 environment, as shown in this example. NOTE: The .IFB settings listed in Step 1 below show ROW_ID values for Siebel Business Applications. If you are using Siebel Industry Applications (SIA), first run the SQL suggested in 477627.1 (Doc ID) on My Oracle Support to get the ROW_ID values, and then replace the corresponding ROW_ID values in the .IFB settings for Step 1. This document was previously published as Siebel Technical Note 925. To migrate a hierarchical list of values
BATCH = 1-<last batch number as specified in step 7> |
| Siebel Enterprise Integration Manager Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
