Siebel Energy Guide > Technical Reference for the Price Comparison Feature >
SIS OM PC Competitive Pricing Report Process Workflow
The workflow is called by a SmartScript session that is invoked by clicking the CP Report button in the Relationships view of the Product Comparison screen. Figure 41 shows this workflow.
Figure 41. SIS OM PC Competitive Pricing Report Process Workflow
Workflow Description. This workflow performs the following actions:
- Opportunity Null? Delete Existing PC Quotes. These steps check to determine whether an opportunity exists for the Price Comparison. If there is an opportunity, then all existing price comparison quotes are deleted.
- Get New RowId. Create Opportunity. These steps create a new opportunity if an opportunity does not exist.
- Setup Question-Field Mapping. This step maps the SmartScript session questions to fields of a quote.
- CP Report Create Quotes. This step converts the answers from the SmartScript session into a competitor quote by using the mapping created in the previous step. Using the answers from the SmartScript session, the data is generated for the report.
- Execute Report. This step executes the report by using the data set generated by the previous step.
Table 21 lists the SIS OM PC Competitive Pricing Report Process Workflow steps, methods, and business services.
Table 21. Business Service Methods for SIS OM Competitive Pricing Report Process Workflow
Delete Existing PC Quotes |
SIS OM Pricing Calculator Service |
Get New RowId |
Get Next RowId |
Setup Question-Field Mapping |
Setup Question Field Map |
CP Report Create Quotes |
Execute Report |
Execute Report |
Report Service |
