Siebel Energy Guide > Defining Integration Workflows for Siebel Energy > Sample Integration Workflow: CUT Send Account DataThis topic examines a send-type sample workflow process to help you understand how the workflow process is set up. This sample workflow process sends an XML string, created from an account record, to an IBM MQSeries queue. For more information about profiles, see Profiles in Siebel Energy. Figure 25 shows this workflow. Workflow Description. This workflow performs the following actions:
CUT Send Account Data Workflow PropertiesProperties that apply to all steps of a workflow process are called workflow process properties. These properties apply to all workflow processes. These properties follow: The CUT Send Account Data workflow has the following additional properties:
| Siebel Energy Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
