Siebel Energy Guide > Premises in Siebel Energy >
Registering a Premises Hookup in Siebel Energy (End User)
Premises can be associated with one or more service points. If your application is configured to allow you to manage meters separately from service points, then you can associate a meter with a premises through a service point. Otherwise, you can associate a meter point (the meter) only with a premises. Adding Service Points to Premises
To add a service point and associate it with a premises, follow this procedure. To add a service point and associate it with a premises
- Navigate to the Administration - Data screen, then the Premises view.
- In the All Premises list, select a premises record.
- Click the Service Points view tab.
- In the Service Points list, add a record.
The Service Points dialog box appears with a list of service points that are not associated with any premises.
- In the dialog box, select an existing service point or create a new service point.
- In the Service Points list, complete the necessary fields.
Some fields are described in the following table.
Removal Date |
Select the date and time when the service point is removed from the premises. |
Location |
Type a description of the location of the service point. |
Product |
Select a product for the service point. Only products for which the value in the product Type field is Service Point and for which the product Service Type field is not null are available for selection. |
Associating Meters With Service Points
To associate a meter with a service point, follow this procedure. To associate a meter with a service point
- Click the Meter Location view tab.
- In the Meter Location form, add a record, and complete the necessary fields.
Meter ID |
Select the ID for the meter. |
Start Date |
Select the date and time when the meter is associated with the service point. |
