Siebel Field Service Guide > Business Service Methods in Siebel Field Service > Methods for Schedules > ConfirmAppointment MethodConfirmAppointment confirms the selected appointment (time slot) that the GetAppointment method reserves. The activity is assigned to the owner and starts during the selected time slot. This method also releases the other time slots that the GetAppointment method previously reserved. The GetAppointment and GetAppointments methods generate a property set containing a list of time slots that are available for the activity. Each returned time slot contains properties. The time slot that these methods pass to the ConfirmAppointment method includes the Slot Start - SR Time Zone property. This property indicates the slot start time in the time zone of the service region for the activity. Invoked FromThis method is called when a user clicks the Book Appointment button (in the Schedule view in the Activity List view of the Activities screen), and selects a time slot from the Pick Appointment dialog box (Abs Result Pick Applet). ArgumentsTable 66 describes the arguments for this method.
There are no return values for this method. This method needs an additional input property request key for the Server Requests business service. For more information, see About Calling the ABS and Optimizer Methods. The following example script defines this additional input: var SRMSvc = TheApplication().GetService("Server Requests"); |
| Siebel Field Service Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
