Siebel Field Service Guide > Business Service Methods in Siebel Field Service > Business Service Methods for Agreements > GenerateRCCharge MethodGenerateRCCharge generates the recurring charge (RC) for an agreement line item. Invoked FromThis method is called by the FS - Generate RC Charge workflow. The workflow retrieves and converts the asset readings to charge amounts. The input date for this workflow is in the local time format. The workflow converts this format to the ODBC format (YY-MM-DD). After the RC amount is generated, the workflow also updates the RC last-charged date on the charge plan. |
Siebel Field Service Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
