Siebel Field Service Guide > Business Service Methods in Siebel Field Service > Business Service Methods for Agreements > GenerateUsageCharge MethodGenerateUsageCharge generates the usage charge for an agreement line item by using asset usage. Invoked FromThis method is called by the FS - Generate Usage Charge workflow. The workflow retrieves and converts the asset readings to charge amounts. The input date for this workflow is in the local time format. The workflow converts this format to ODBC format (YY-MM-DD). After the usage charge is generated, the workflow also updates the usage last-charged date on the charge plan. |
Siebel Field Service Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
