Siebel Field Service Guide > Business Service Methods in Siebel Field Service > Business Service Methods for Charges > CreateTimeCharge MethodCreateTimeCharge creates charges by using reported time. This method creates the time charges for an activity by using the hourly rate of the activity owner. If you do not want to charge expense adjustment, then remove the ChargeBusinessServiceMethod1 user property from the Time Sheet Daily Hours Item business component. For more information, see Table 60. This method is not used as part of any workflow process. Invoked FromThis method is called directly from the FS Charge List Applet - Auto Charge (in the Charges view in the Activity List view of the Activities screen). The business service is called directly from the applet class. |
| Siebel Field Service Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
