Siebel Field Service Guide > Business Service Methods in Siebel Field Service > Business Service Methods for Charges > CreateTimeEntitlementCharge MethodCreateTimeEntitlementCharge creates time entitlement adjustments. This method adjusts the cost of the hourly resource by using the entitlement associated with an activity. If you do not want to charge time adjustment, then remove the ChargeBusinessServiceMethod2 user property from the Time Sheet Daily Hours Item business component. For more information, see Table 60. This method is not used as part of any workflow process. Invoked FromThis method is called directly from the FS Charge List Applet - Auto Charge (in the Charges view in the Activity List view of the Activities screen). The business service is called directly from the applet class. |
| Siebel Field Service Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
