Table 34. Parameters for the Cycle Counting Engine
Mode |
SQL |
Specifies the WHERE clause to set up criteria and count the products that meet that criteria. |
Id |
Specifies the ID of the inventory location or the inventory type. The Cycle Counting Engine counts only the products related to that location or type. |
TempTbl |
Places all the required parameters into a temporary table with a temporary Client Request ID and passes that ID to the server to retrieve the parameters from Temp Table. NOTE: Do not run component jobs in TempTbl mode to call the Cycle Counting Engine. This mode is reserved for interactive engine jobs sent directly from a client application.
ClientId |
A row ID for retrieving parameters from the temp table |
This parameter is required when the Mode parameter is TempTbl. |
RowID |
Row ID of an inventory location or inventory type |
This parameter is required when the Mode parameter is Id. |
StartDT |
Start Date |
Specifies the proposed start date of cycle counting. This parameter is required. |
EndDT |
End Date |
Specifies the proposed end date of cycle counting. This parameter is required. |
Where |
Where Clause |
Specifies the Business Component Search Spec mode. This parameter is required when the Mode parameter is SQL. |
Loc/Type |
Inventory Location or Inventory Type |
This parameter is required when the Mode parameter is Id or TempTbl. |
