Siebel Field Service Guide > Scheduling Using Siebel Scheduler > Process of Managing Schedules Using Siebel Scheduler > Optimizing Schedules (End User)You optimize schedules to efficiently use labor in your service organization. For more information about optimizing schedules, see About the Schedule Optimizer. You can optimize the schedule for a service region by using either of the following methods:
This task is a step of Process of Managing Schedules Using Siebel Scheduler. Using the Workflow Manager to Optimize SchedulesScheduling is a business process. To use the Optimizer, you must fully integrate it into the normal process of delivering service. The Workflow Manager is the primary vehicle for this integration. For more information about the input arguments that the Optimizer methods use and about the values that the Optimizer methods return, see Methods for the Optimizer and About Calling the ABS and Optimizer Methods. Most customers using the Optimizer use the Workflow Manager to accomplish the following tasks:
Optimizing Schedules for Service RegionsYou can optimize a service region schedule. To optimize a schedule for a service region
Stopping Optimization of Schedules for Service RegionsYou can stop an ongoing optimization of a selected service region. Stopping an optimization might not happen immediately because the Optimizer completes the solution that is in process and saves the solution in the Siebel database. NOTE: You must manually stop an optimization. The Workflow Manager or repeating component jobs cannot send this command. To stop the optimization of a schedule for a service region
About Availability of PartsPart availability is a constraint only for the Optimizer, not the ABS. Data loaded into the Optimizer cache includes all trunk inventories for all field service engineers in a service region. The Optimizer - Consider Parts parameter uses the part availability in the trunk inventory for an engineer when considering the engineer for assignment to an activity. The Optimizer - Parts Period parameter determines the number of hours that the loaded part list is valid for an optimization. For more information, see Defining Cost Functions for the Optimizer and Parameters for Schedules. If the Optimizer considers part availability, and if the activity includes a part with an order line item number, then you can drop-ship the part for the service call. The Optimizer does not consider the part as a constraint in scheduling. NOTE: To use parts in a trunk inventory for a service call, the parts must have a Status field of Good and an Availability field of On Hand. About Optimization and Activity StatusesThe Optimizer can change the status of activities to obtain the best scheduling. When you click the Load Optimizer button in the Service Region List view of the Administration - Scheduling screen, the Optimizer loads activities (with associated statuses) from the Siebel database. Likewise, when you click the Load button in the Activities view in the Service Region List view of the Administration - Scheduling screen, the Optimizer loads the activity (with the associated status) from the Siebel database. If you change the status of an activity, immediately click the Load Optimizer button or the Load button, and click the Optimize button in the Service Region List view of the Administration - Scheduling screen, then the changed activity status is in effect after the Optimizer runs. However, the Optimizer can change the status of activities. So if you change the status of an activity and do not click the Load Optimizer button or the Load button, then the changed activity status can revert to the status value in the Optimizer cache if the Optimizer runs again. |
| Siebel Field Service Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
