Siebel Forecasting Guide > Forecasting (End User) > About Forecast Adjustments > Adjusting a Detail Depth ForecastIn a detail depth forecast, each revenue line item in the Details view is rolled up through the hierarchy. As a result, senior management has access to every forecast detail revenue item for the review. In this scenario, users need to make sure that every adjustment is made in the Details view. After adjusting the details, users must click Rollup to recalculate the modified forecast. To see forecast details by periodic summary, users can view the forecast from the Summary tab. If the detail depth is Revenue detail, a manager can edit the Adjustment field for subordinates only in the Forecast Detail view. In the manager's Forecast Summary view, the Adjustment field for subordinates is read-only as shown in Table 10. Once a manager adjusts a subordinate's detail record, the Siebel application maintains an adjustment history. Levels of management above can view the adjustment history, however, the subordinate, whose forecast record was adjusted cannot view the adjustment. NOTE: If unclear about the forecast type your company uses, consult your Siebel administrator or a member of your sales operations team. To adjust a detail depth forecast
| Siebel Forecasting Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
