| Siebel Forecasting Guide > Forecasting User Properties >  Forecast 2000 - Forecast User Properties
 Table 12 describes the user properties associated with the business component: Forecast 2000 - Forecast.
Table 12.	Forecast 2000 - Forecast
    | Associate: Completion Timeout (Client) | 120 (default) | Maximum amount of time (in seconds) to wait on the client for a subordinate's forecast to finish before skipping the association and returning an error. |
    | Associate: Completion Timeout (Server) | 1200 (default) | Maximum amount of time to wait (in seconds) on the server for a subordinate's forecast to finish before skipping the association and returning an error. |
    | Associate: Sleep Time Between Attempts | 5 (default) | Amount of time to wait (in seconds) between checks for completion of subordinate's forecast. |
    | Forecast Analysis BC | Forecast 2000 - Forecast Item Detail Flat | The business component whose records are displayed in the child applet in the Analysis view, when parent records are selected for comparison. |
    | Forecast Refresh | Y or N | If this property is not defined, the Refresh button is not enabled.  |
    | Forecast Rollup | [Link Type] = LookupValue ('FCST_FCSTITEM_LINK_TYPE', 'Own Item'), or, [Link Type] = LookupValue ('FCST_FCSTITEM_LINK_TYPE', 'Item') | If active, this search specification is applied on the Forecast Detail business component during rollup. This search specification defines that only those records that have a Link Type value of Own Item or Item are rolled up. |
    | Forecast UoM Conversion | Y or N | If enabled, the UoM conversion is done when generating a forecast. |
    | Skip Existing Forecast Series Date | Y | If enabled, does not show dates for which forecasts of the currently selected series already exist. |
    | Named Search: Forecast Series Date Range   | [Date] >= '&FCST_DATE_LOWER_BOUND' and [Date] <= '&FCST_END_DATE' | If active, this search specification is applied to the Revenue business component during forecast creation. This forecast is typically activated to make sure that the revenues returned by the search are within the Forecast Date range. For more information about this user property, see Using the Named Search: Forecast Series Date Range User Property. |
    | Revenue Aggregation Field n | Field names on the Forecast 2000 - Forecast Item Detail Flat business component | The fields that are aggregated during forecast rollup. Rollup aggregates the forecast details by forecast period, and sums up the fields configured here when creating each summary record. The Revenue Aggregation Field 6 user property is deactivated. You must use this user property as the first of any custom user properties. |
 Using the Named Search: Forecast Series Date Range User PropertyUse this user property when querying the revenue records to include in the current forecast. The default is to include all records, in the range specified by the forecast. The value of the Named Search: Forecast Series Date Range user property must be a valid search specification. The search specification (as well as the Auto and Assoc search specifications) can use special variables as defined in the Forecast Series and Forecast Series Date business components. For example, if the default value of Named Search: Forecast Series Date Range is: [Date] >= '&FCST_DATE_LOWER_BOUND' and [Date] <= '&FCST_END_DATE' then values between the Date - Lower Bound field and the End Date field of the Forecast 2000 -- Forecast Series Date business component are returned. In such a case:
The variable &FCST_DATE_LOWER_ BOUND represents the Date - Lower Bound field, which is the History View Date if it has a value.
If History View Date does not have a value, the Date - Lower Bound field is the History Edit date if it has a value, or the Start Date if the History Edit date does not have a value.
 You can deactivate and modify the values of the Named Search: Forecast Series Date Range user property; however, you cannot create new instances of it.  NOTE:  If you deactivate the Named Search: Forecast Series Date Range user property, you can make sure that the revenues that enter the forecast are limited by date, by modifying the Auto and Assoc search specifications of the Forecast Series to include similar criteria. |
