You can type text directly into a text field (shown in Figure 4-1). You click in the field before typing this text.
To more easily enter text in text fields that can contain a large amount of text, you can click and drag the resizing indicator in the bottom right corner of the field to make the field larger. You can also use the resizing indicator (shown in Figure 4-2) to make the field smaller. In some browsers, you must click in the text field to see the resizing indicator.
Developers can customize the Siebel application to save or to not save the size of a field that you resize. They can also customize the Siebel application to not use this resize feature for fields.
