Option buttons, also called radio buttons (shown in Figure 4-4), allow you to choose one of several options in a set. An option button appears as a circle, with a smaller, filled circle inside it when you select the option. You cannot select more than one option button in a set.
You can press the up or down arrows and the space bar to select the option.
