The application-level menu (shown in Figure 3-2) is located on the application banner at the top left side of the application window, and includes the following options:
File
Edit
View
Navigate
Query
Tools
Help
The functionality provided by each menu in the application-level menu depends on the Siebel application and the configuration you use. Each menu option lets you perform a task. Look for topics in this document that explain the task you want to perform to find out how you can use a menu and its options.
