You can select saved queries from the drop-down list for the Saved Queries field on the menu toolbar (shown in Figure 3-3). In this list, you can access your saved queries and the predefined queries established by your organization. For more information about the menu toolbar, see "About the Menu Toolbar".
Figure 3-3 also shows an example of the drop-down list for the Saved Queries field in the menu toolbar. For more information about saved queries, see Chapter 7, "Using Query to Locate Information."
