Data can appear in chart format (shown in Figure 3-8). Charts are graphical representations of data and are available as views in some screens. Use charts to compare data sets. Typically, you can access a chart from the second level view bar.
Use the drop-downs list at the top of the chart to determine the data to include in the chart. Most charts also include a control buttons representing chart types from which you can select the format of the chart, for example, a bar chart or a pie chart.
You can save charts in the Siebel application for use in other applications, for example, in Microsoft PowerPoint. When you save a chart, you have a copy of the chart that you can include in presentations, documents, or other places where you might want to display it.
To save a chart
Navigate to the chart you want to save.
Right-click the chart, and select Save Image As.
In the dialog box that appears, do the following:
Navigate to the location where you want to save the chart.
Do not change the default file name, or enter a new name in the File name field.
Select an image type from the drop-down list for the Save as type field.
Click Save.
