The Simplified User Interface is available as an alternative theme for the Siebel Open UI client. Although the Simplified UI is not the default theme, you can configure the Siebel Open UI client to use this theme. For information about setting themes, see "Setting Themes".
The main elements of a home page using the Simplified UI theme are as follows:
The home page contains familiar elements, such as, My Quotes and the menu toolbar.
On the right side of the screen are a series of Springboard icons (such as, Home, Accounts, Contacts, Calendar, Opportunities, and so on) that you can click or tap to access a particular screen.
After you choose a screen, you can access available views using the floating side drawer on the right side of the screen.
Additionally, Springboard icons appear within a horizontal scroll list above the selected screen, and the buttons in the application toolbar appear when you click the icon next to the Oracle logo.
