The Siebel Open UI client supports screen readers that work in browser-based applications. Screen readers provide an audible description of the field contents as you navigate through the user interface. It is recommended that you use screen readers that comply with Accessible Rich Internet Applications (ARIA).
The Siebel Open UI client supports screen readers that are browser-compatible because it is a standards-based Web application. Some browsers interpret Accessible Rich Internet Applications (ARIA) and Version 2.0 of Web Content Accessibility Guidelines (WCAG) better than other browsers. Use the appropriate browser for your Siebel implementation. Consult with the vendor for your screen reader to use it with a Siebel application.
If you use a screen reader, then you hear the levels of the bar region that denote user interface areas. Table A-1 shows the level of the bar region that corresponds to each user interface area that sighted users work with.
Table A-1 Levels of Bar Region for User Interface Areas
| User Interface Area | Level of Bar Region |
One of the following:
First level |
Second level |
Third level |
Fourth level |
