Table 14-2 lists the keyboard shortcuts you can use to access options available on the Help application-level menu.
Table 14-2 Online Help Keyboard Shortcuts
Display the online help.
CTRL+H
Screen
Display information about a record.
CTRL+ALT+K
Record
Display technical support information, including system information.
CTRL+ALT+J
Application
