Go to primary content
Siebel CRM Fundamentals Guide
Siebel Innovation Pack 2016
E52425-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
Editing Records
To edit a record, you must have appropriate access privileges.
To edit a record
  1. Find and select the record you want to change.
  2. Change the fields in the record, and step off the record to save your changes.
