You can see a count of the number of records in a list without navigating to the last record in that list. If you execute a query, then this function shows you the total number of records in the query results.
To display a record count
(Optional) Execute a query.
Click the Cogwheel icon, and then click Record Count.
The Record Count dialog box appears.
If you do not execute a query, then this dialog box shows the total number of records in the active list.
If you execute a query, then this dialog box shows the total number of records that match your query criteria.
